Happy gas is on the way!!!
The Itch
In De Nile...
Brat said:
So what shot are you going with on the 10?
100!!!:rock: :rock: :rock: :rock: :rock: :eek: :dontknow:
Has that Bratmobile even made it to a track yet?:marchmellow:
Well that should be o.k.are you going to have your SCT set up for the 100 shot:dontknow: I hope so or you may go BOOM.And no havent made it to the track yet.
I have 3 tunes from Sean but I'm going to run 93 gas with the 91 octane tune with a few gallons of race fuel. :dontknow:
My biggest concern right now is, I want the system to be as invisible as possible. Mine probably won't be jumping out of the hood.
I wish Mickey lived closer. He did your install didn't he? Your's looks great.:rock:
just make sure your not on the lean side....too fat is ok....id dyno it on the spray with the a/f hooked up just too make sure....easy way to make sure you not part of the "blown motor club"!
Good Luck bro!
Good Luck bro!
whats wrong with the blown motor club:confused: i joined last year
Well when you install the nos you need to dyno the truck to make sure the a/f is good and you are not running rich or lean.I believe that if you run 93 gas with the 91 octane tune with the race fuel you will be flirting with a blown moter.
Good Luck bro!
I just found a tuner with a dyno not far from my house. Some guys at the track recommended him. I won't pull the trigger the first time unless it's on a dyno...;)
Good choice.:rock: :rock: :rock:
Hey ITCH,where's your latest trophy pics from QS&L ???? :dontknow: :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
