Ive been installing my new stereo today and I have tapped into the revers lights, steering wheel control for deck, installed amp bypass harness.
The steering wheel control wire is up in the column so had that apart.
Entire passenger side dash has been removed unplugged both cig lighters, air bag connection, heating, fan connectors..
Now
I turn on the key, lights work, radio works, everything seams normal.
most of the cluster lights are on like it would be when you typically start up the truck.. BUT the gauges don't sweep, the fuel pump dont wine and the start button does squat..
I wiggled on a few connectors and wires searching for my steering wheel control wire in the steering column one of the devices that i was wiggling and looking threw the wires says on the back side " just noticed Immobilizer" on it i figure thats where the key matches up its pin to start the truck...
But i have not disconnected anything or unplugged any of the clips ..
Ive checked all the fuses under the hood as well they all seam to be perfectly intact..
any ideas what it could be?? or where to start looking... I have since removed my two wires that I spliced in and that made no difference
Now
