Viper Beau said:
I noticed in my reading of some of the threads that some of you guys don't recommend doing head work with certain applications, i.e. s/c. Just wanted to know from those guys who build and have had motors rebuilt your thoughts on when to do head work and when not to. My reason for the question is I am torn between a NOS setup or a s/c. I do plan to forge the pistons, rods, and do billet mains (800hp, give or take). Where will head work come into play?
FYI, I am not as versed in the mechanical lingo so please dumb your answers down for the mechanically impaired.
If you are going with a typical street-style (low volume) forced induction system, a worthwhile and cheap mod is to back-cut the valves in your stock heads. This is something you CAN do without worrying about losing boost pressure.
The lower capacity blowers lack the ability to maintain boost pressure once you open up a "hole" at the other end by doing more radical head mods. I.O.W. the column of air that used to back up and create boost pressure now flows
through the engine and the blower can't keep up (not enough capacity). You can compensate
to a point by increasing boost but you will rapidly reach a point where heat (among other things) becomes an issue because you are going outside of the blowers intended use range.
Options for big power (say the 1000 and up range) (aside from Nitrous):
1. *Big Head Flow
combined with Big Capacity Blowers = Big Power.
2. HUGE capacity cylinder heads WITHOUT a blower of any kind (or any nitrous) can also = Big Power. BUT COSTLY and not practical for the trucks.
*The first option gives you more usable power for a street style vehicle.
The 2nd option can really confuse people that went with option #1.
Another route to go for a more usable power plan (Under 1000 HP): Go with Strikers and a cam and hit it with a big shot of nitrous anytime you want; as it sounds like you want to go with stronger internals anyway.
Or another route- Strikers, cam
turbo and nitrous.
Ronnie
