blackviper said:
Don't use a helicoil, use a timesert instead.
http://www.timesert.com/
dont use helicoil on aluminum never never never ,,,as he says ,,,once you use a helicoil on aluminum you will never get bolt out again ,,,we wont do this on tooling molds made of aluminum either ,,,
works good when you first do it ,but when it gets hot you are swelling a aluminum head with a stainless steel threaded insert ,,,that bolt will never come out again without pulling and stripping out thread and insert then you end up with a bigger screwed up hole ,,,timesert all the way ,,or you can go to next size thread and drill and tap it ,,,with it being last hole on head it will be easier to drill out to next size and tap it ,,,you can do it with head still on if you have access to a right angle drill head and a short drill bit
