ScottVa
I just installed Billy Boat headers on an 04 and now the steering knuckle/u-joint is hitting one of the header pipes. The truck won't steer correctly. Any suggestions? HELP!!
............................. BINGO!JTS VENOM PERFORMANCE said:depends on where ya got them, the RCs are different from QCs
moparracing said:i've got b&b & it is close to the steering - you must have the wrong one's if it's hitting...... get 'em jet hot coated while you have them out:
http://www.jet-hot.com/
ScottVa said:Thanks guys for the help. Moparracing, I appreciate the picture. You have tons of clearance compared to mine, needless to say. I might be able to grind the corners of that knuckle down enough to get clearance. Then I have the problem of the bolt head making clearance which has me stumped. Stink, thanks for the header denting idea. I may look into that as well. thanks again, guys.
hcetzneb said:WOOOOO dont grind the steering shalf... NOO That shaft is your olny connection to you steering your tires or keeping them going straight. I wouldnt want that shalf breaking at 100 mph ... either call the place you bought them from and get the correct ones or dimple the header...
Its simple to do just do go hitting it.. torch the area to a nice red color and take a ballpen hammer with the round end and hit it with another hammer...... with the round ballpen end you will get a nice shape it wont look all beat up Please dont grind that shalft
