headers just went to be coated
dragon
phoenix arizona
mopar headers just went to jet coating to get coated i should have them back in a week and if all gos well i should have the headers w/catless mids, cat back system and performance pcm installed before :santaclaus:. i do have a question about the catless mids will i need the 02 sims for the downstream 02 sensors i hear everyone talking about?:dontknow: what ones would you sugest? i would like a plug and play but understand if i have to wire them in.
:burnout:
if you remove the rears only, then no need for shims. Its when you get into modifying the fronts is where you need them.
The rears are the restrictive ones...remove those, and just leave the front on....
-Red
I'd remove the mid piping sence its a smaller diameter than the rest of your system...i never had a issue with sensors as i left the front ones in and sealed up the rear ones in a air tight bag.
