ram_vs_cougar
Ok I have a question about my headlights. Bought a set of LED headlights and when i took out my OEM Headlights and I saw where the previous owner hard wired the OEM Fog lights to automatically come on when you turn on the parking lights. Never really paid attention to it. Since they are hard wired, you can never turn them off, they stay on when the parking lights are on, they are on when the headlights are on , they are on when the high beams are on. I wanted to know if it was a bad thing if i were to install the new headlights with the current set up or if i should undo the current set up and then install the new headlights. Do you think it will be too much of a Load if i install them with the fog lights hard wired?
On the Driver Side:The Fog lights and the small LEDs ( 6 total/ headlight) would be connected to the turn signal wire (White/Yellow wire) and would always be on if i turn the parking lights on. If i turn on the Head lights or my brights the Fog lights and LEDs will stay on as well.
On the passenger side:Same thing the LEDs would be wired to the turn signal wire (Gray/White wire) and will stay on all the time until i turn off the parking lights.
I don't mind them being on all the time unless this is a bad thing...(i.e. will be too much of a load, will drain the crap out of the battery, blow a fuse, cause the truck to run weak etc ...)
Any info would be greatly appreciated!!:rock: :rock: :congrats: :congrats:
