areuv
need any info on this code, I have intermitten crank $ camshaft signals, truck runs a little then starts popping out exhaust, any help is greatly appreciated, TIA
That sounds like the cam sensor. The crank sensor is under the truck on the passenger side at the back of the engine. It's triggered by the the flywheel.RedSrt007 said:Check your crank sensor...Remove / re-install
Above the water pump, under the throttlebody. Disconnect the connector, then reconnect it...
