Help.....again
BLACK10
Panama City FL
Anyone know which wire on the fuel injectors is the negative ? and also need to know which wire on the TPS to tap into for my meth injection I am using the FJO setup
For the injectors the brown with violet tracer wires are all battery supplied voltage. Then the other wires brown with some other color are the PCM controlled grounds. NOTE: the number 6 injector uses the violet tracer on both wires.
The TPS signal wire is brown with orange.
My '04 SM has BN/WH as the common rail +12V, and BR/tracer as the control (to ground) except for #9 is solid BN-no tracer, diff color tracers for ea cyl.
