VENOMOUS1 RACING
I have been for the most part silently trying to fix an issue with the 10 that aggrevates the crap outta me. Usually ask for help at my wits end, so here I am. My mileage has gone to crap from 14.5 to about 11.5 and the power seems to come and go. I am 99% confident it is a sensor, but which one?
Scenario:
Mostly happens at cruising speed around 60MPH with a steady throttle and even road. Seems to have something to do with the throttle being barely open, whether cruising through a parking lot with the throttle barely cracked, or doing 60 with throttle barely cracked. Pretty much another reason I was thinking TPS. The engine will start sputtering and falls on its face and I have to give more throttle to maintain speed. As soon as I hit the gas a little more, she darts forward and quits the sputtering. While she does this there is a messload of unburned fuel coming out the exhaust to the point where I smell it in the cab at 60mph? I have tried to just let this continue on to get a check engine light or something, but she never says anything. ( my check engine light does work) She also shifts quicker than she used to like and older car with a vacuum leak at the tranny modulator. Just normal accelerating it shifts to second at about 10 mph and all the other gears early bogging the motor down. I believe this is caused by whatever sensor is involved with tranny shift points also.
Here are the things I have done to remedy this situation to no avail and what I think could be culprit. I am going to try and borrow a Scan Tool that Chrysler uses to log and visually watch the sensors as I am driving and when it acts up see what is acting up.
1. Changed plugs and wires
2. Added Screamin Demon coil packs.
3. Changed tranny fluid and filter and new tranny sensors from MOPAR
4. Changed TPS as this seemed reasonable by everyone else's issues like this.
None of the above made the slightest difference at all with respect to fixing the issue at hand.
Things I think could be culprit:
1. Fuel pump/filter which I cannot access to change? Acetone her?
2. MAP sensor since that feed the computer all airflow info since we have no
MAF.
3. Coolant temp sensor- Have seen them read 0 degrees on a 90 degree day and vice versa.
4. Intake Air Sensor- seen them read incorrect temps and cause issues.
5. Cam and Crank sensors? I go more likely with cam sensor as I've seen more cars not even run with bad crank sensor.
Please help if you have run into anything similar or have any knowledge to share.
Thanks, Scott
Scenario:
MAF.
Thanks, Scott
