HELP! NEED SOME ODD SIZED BOLTS!
SANCHOBA
TEXAS A&M DAD
INGLESIDE,TX.
need header bolts for my iron v-10, 5/16"x18 1" long but have to have a 3/8" six sided hex (for clearance). contacted two websites to no avail. trucks in shop waiting on the bolts....help a brother out!
Are they for the 10 or the same as the 10? If so I have all mine that I took out of the oem headers if that's what you need.....
Other than that I have a lot of aftermarket bolts in my engine bay and I took measurements and got them from allensfasteners dot com
no for my other truck.....5/16" normally have a 1/2" head, but i nead a 3/8" head
Well found some stage 8 with a 7/16" head,hopefully they will work
If you still need them try a Machinist Supply Place. They carry alot of Specialty fasteners and may be alot cheaper than Speed Shops.
Or Hedman part 9006. 5/16-18 X 1 Hedder Bolts- ZINC PLATED (16 Pack)
"This section contains the same quality hedder and collector bolts we put into every set of Hedman Hedders. Even the best designed headers may provide practically zero bolt clearance. But, with Hedman's smaller 3/8" wrench size, these hedder bolts have a smaller head than atandard header bolts, providing more clearance for installation , tighening or removal."
thanks for the find..if the stage 8 won't work i'll get some of these,thanks:congrats:
