shorty
I posted under “Tranny and Cruise Problem†earlier. Really in need of help. The check engine light comes on and the code is 0740 which is the torque converter unlocking. Put the truck in cruise and the throttle full open for half a second and then stabilizes but pulses 300-500 rpm, as if you are pressing on the foot feed and letting off. Changed all three solenoids out twice. Seemed to work for a while but started again. Here’s the problem. I clear the code and the thing starts working perfectly. 200 to 300 miles and the light comes on again and the cruise starts gyrating again. I pull over, clear the fault code and all is well again. By the way, even with the 0740 code on the torque converter is not unlocking. Something else seems to be causing the code to come on and then triggers the cruise control problem. Any help or advice will be most welcome. :dontknow:
