help please
migueldid
españa
hello , see if someone knows it can be ;
I have a dodge srt10 2004 that he broke the clutch , I would have changed but only the disk , not the whole kit and now happens to me that cold is more or less okay but when I get on the road and put my 6 speed when changing a 5 speed comes very rough and then if step 5-6 I feel the same .
the reverse is equally difficult for me to put it and this only hot ..
my question is; if you change the whole kit provider , mace , bearing and its corresponding valvulina , I remove that problem ?.
If the translation is bad sorry for me this traducciendo google
Before a clutch I would try to bleed the clutch as well as try to re-align the actual shifter handle. Two very simple things that will hurt nothing if that isn't your issue.
Really should resurface the flywheel and change, both, disk and pressure plate at the same time. the wear grooves and hot spots from the existing metals ontop of a new disk will create a rough engagment. Like only changing the brake pads on worn rotors. the disk will not last long and can be erratic. The release bearing is a fault on these trucks make sure you bleed the system to changeout the fluid for new. There is a reverse lockout that can be problematic as well. Check with Venomous1. I think he removes the spring in the solenoid and disconnects it.
How lucky you are to have competent people and good parts because it is impossible to find pieces here and order them online like crazy give me a little scary if you get confused.
We have vendors here that can get you the parts you need.
Buen día Miguel,
Cuando haga el remplazo del embrague, siempre es buena idea cambiar todos los componentes que sirven la función de los cambios dentro de la transmisión. El amo y esclavo a veces sirven por un tiempo pero después de poco se descomponen. Es buena idea cambiar todo eso la primera vez para prevenir tener que bajar la transmisión de nuevo por un problema tan sencillo que se pudiera haber prevenido al hacer el remplazo en conjunto con el embrague.
Buen día Miguel,
Eso voy a tener que hacer pero me la vendieron así y encima el de la tienda no se quiere hacer responsable....en fin todo problemas
who recommend me to order the complete kit on the forum .
I next factory because I will not touch engine or strange things
Una tienda de concesión rara vez se hace responsable por automóviles usados a menos que haga comprado una garantía sea por la tienda o por el banco que le haga dado el préstamo para fallas mecánicas. Su mejor opción sería buscar un mecánico especializado en vehículos americanos.
pero si el coche salio de la tienda con embrague nuevo y a los 60km se rompió... garantía de la pieza exijo, no??
confusion
Miguel , lamento oír hablar de su problema. Póngase en contacto con Arska2 en nuestro foro. Él es el miembro más conocedores de camiones Ram SRT10 en Eurpoe . He cambiado tu perfil para poder enviar y recibir mensajes privados . Buena suerte , amigo!
arska es en Alemania y no un hombre de las cavernas vendedor.
Lol!!! I love google translate. Nothing ever comes out the right way, but it gets the message across.
