HAMRDWN
- Joined
- May 23, 2016
- Messages
- 2
- Reaction score
- 0
I am hoping someone on here could point me in the right direction. The lower ball joints on my truck need to be replaced so I ordered a set of Moogs from rockauto along with UCA and outer tie rod ends. The problem I ran into is that I cannot find an adapter kit that will work for me to press the old ball joints out. I have done ball joints before and never had this many issues. So I eventually decide to change the entire LCA but the part number that I found and ordered are no longer sold by dodge (5290614AE/5290615AE). By the way it is a 2006 Quad cab. Can someone confirm whether or not the LCA from the 2005's are the same? Or if anyone has done this before, what was the part number on the press kit that you used and from which auto part store? I also found that the outer tie rod ends i ordered (Moog) were too small. They were M17x1.5 and I think I need M18x1.5 which would be the same ones from the mega cabs. Any useful advice would be appreciated. Thanks
