help
v10 fat
the uk
hi guys . well the uk winter is looming so i have put truck in to storage. wanted to paint brake calipers red as they are looking a bit tired and give the wheels a good clean so i do the fronts then when i get to back i cannot remove my wheels? took all nuts of and hit wheel from back with mallet and timber block. they are on solid {trying not to buckel wheel} still not moving help thanks scott :confused:
I would try loosening the lug nuts just slightly on both sides. Maybe 1/8th inch loose. Lower the truck back on the ground and try rocking the truck side to side. Use the weight of the truck to your advantage. If that doesn't break the wheels loose I don't know what your gonna do.
I had the same problem..its the two disimiliar metals and the salty, humid air.try SILVRSRT10'S suggestion. i took mine to a shop and they beat on the tires as they rotated the wheel:ahhhhh: (inside and out) and they finally popped off. before you put them back on brush the mating surfaces with never seize.:rock:
