HELP!
Tooloe
Central Texas
ok guys i dunno whats going on here the driverside door speaker and the Sub will not work? all the wires are good not lose or anything is there any trick fuses or any tips on trouble shooting the problem? help me please lol i'v got the whole dash torn apart and the door panel off tring to get it all strightend out!
check the wires in the plug at the sub amp in the lower center console. I spliced in there to hook up the subs I got from you. The plug there can be finicky.
all fuses are good.. i'm kinda stumped.. and i'v very good at Wiring audio and nitrous systems..so i'm good with wires lol so i dunno
ARRESTmeRed04 said:
have you checked the grounds??? maybe the body shop didn't hook them up
good idea know where any of them are at ! lol?:marchmellow: :marchmellow:
The way the radio works is the main marness in the back of the head unit (The big plug) carries all the positive to the amp behind the air bag. Then looped back to head unit (Small plug) In other word all your speakers are grounded through your amp. Check to make sure that both of the plugs are in good. The small plug came out on mine and the sub and the pass. side went out. so I would check there first.
yup everything is connected good just got done double checking radio both plugs are good amp is connected good just the driver side and sub are not working still
You didn't turn the balance to the right and sub off did ya??/ HMMMM Thats kinda weird? I have no clue
