Update guys...Energy Suspension Part # 9-9143R...Available at summit or any Energy Suspension retailer...They are a touch longer, which is good because I think they should be a little longer than stock being that most/ or maybe all don't touch the top spring while sitting...I understand they probably do under slight axle load but I also think the helper spring snubber/bushing could benifit being a little taller...I'm gunna trim a 1/ 4 inch at a time...factory worn our cracked rubber covered foam seem to measure roughly 2 3/4, these are 3 inch..Round 30$ for the set minus fastners, I'm gunna use some stainless torx head screws and lock nuts..I'll update once I get them on and post a screw length and size..
