fastblksrt
Guys can't decide what to get so any information such as pros & cons, HP gains between them is appreciated. Thanks in advance
John Stuttle said:I performed dyno's before and after removing all four cats and gained 15HP. This is with stock exhaust manifolds. - - john
John Stuttle said:Yes i had to use the rear sims. I am using these $25 ones:
http://www.o2simulator.com/
They also have a support forum there.
john
john
moparracing said:the site says you only need one sims for both of the back o2 sensors... is that what you did ?
also, did you completely remove the o2 sensors or just add the o2 sims in with the sensors ??
thanks.
John Stuttle said:I took the sensors out & plugged the holes. Then added the two of the O2 simms - john
