Hilge-essy rebuild
Hilgee
Deforest, WI
Well here is the list of parts that are needed to get the truck in perfect order. My god did Hennessey skimp out on a lot of things in this motor. But we are going to fix it right. After PBJ gets done with tuning it after we put the bigger injectors and the VEC# on look out. These will be my 3 tunes in the VEC 1--- 93 octane 2----- 110 leaded and 3-----e85 which translate to fast, holy cow, and holy sh$$.:rock:
one questions for you guys is the front and rear seal. The motor builder can only get them Dodge for a stupidly high price??
Clevite rod bearings
Chrysler main bearing
JE custom pistons
JE rings
ARP head studs
ARP main studs
Cometic head gaskets
Cometic exhaust gaskets
Darton sleeve
Valve stem seals
Chrysler front & rear seal,
Rear seal adapter gasket
VEC3
96# injectors
jet hot coated headers
Paul
Wow...Paul, you have found the essence of the John Hennessey approach to building twin turbo's...we all benefit from your experience...not much consolation, but thanks!
Joe is doing my internals next month too...get your truck out of the way so I can get in there!
Roy
Roy
Quad cabs before regular cabs.....:D
Maybe one of our Mopar vender guys can help you out on some good priced oem seals. Check out the vendor section.
Roy
What cha doing in there Roy?:)
patrick
Joe has to drop off a Viper up here and he will carry my truck back with him. But I will go to St. Louis to pick it up...hope we can have lunch or dinner...don't know when that will be...can't push an artist as we all know.
Definitely let me know when you are coming. :rock:
Be patient with Joe and you will be rewarded. His work is second to none and he is a great guy. ;)
Sorry for the thread hijack Hilgee. Can't wait to see what Joe squeezes out of your monster. :burnout:
