Viper Grill Emblem
Send email note to [email protected]
for the 2006 truck grille viper emblem.
Different colors available on order.
The SR10 hood scoop SRT-10 insert.
Their email address is [email protected]
The factory piece is held in place with six screw on type washers. You will have to pry them off. It is easier to pry them back a little and then cut them off. The factory black grill will then just come out. Install the SRT-10 piece with supplied nuts. There are two nuts on each stud. Leave one against the emblem, it is used as a spacer and just screw the other on the back side and you are done & tell them Mike Shehorn sent you.
You need to know from the dealer which one you ordered - sneaky pete (older generation) or the full face (newer generation). Then ask [email protected] if they have both and in what colors for the grill.
Our truck is an 06 & we have put the sneaky pete on tailgate & two doors,
& the full face on the grill.
