How to clean rubber off paint
What he said^^^^^! as a painter I keep it by the gallon and it is very quick and safe for paint. Do need to wax afterwards with your preferred wax. Basically an alcohol/naptha mix and naptha is lighter fluid. Wax&grease remover is the generic term to use at any parts store/paint supply store.
All great ideas. So I started cleaning this afternoon and this is what seemed to work best. First I tried Wax and grease remover what a crazy mess it made. then I tried WD-40 worked ok without the smearing mess. Then I tried Bounce sheets they barely took it off. So what I have found best is to get rims and tires that fit inside the wheel wells. Or be prepared to spend a couple hours cleaning.:mad: Thanks for all the ideas.
cryer sheet are great to get bugs of the front.
you could also try a simple green/water mix for the rubber
