azpyroguy
Here is a quick how to install the catch can on a 2006, as they differ from the 2004 and 2005's.
1. Drivers size valve cover, remove the breather line, it will have a check valve on it.
2. Follow it to under the intake, it will connect to a barb fitting.
3. Remove it there, toss the whole assembly aside, you will not re-use.
4. Passenger side valve cover, remove the breather line, it should goto the air box, or to your supercharger intake, toss that whole assembly aside.
5. Cap the fitting on the bottom of the intake with his supplied caps, I used a hose clamp instead of the wire tie.
5a. If you have Superchager, goto autozone, get package of bypass caps, and install one that fits on the supercharger intake fitting, hose clamp that one also.
6. Install catch can on fan schroud bolt.
7. Take the long hose with 90 degrees elbows, feed long side of line under intake, connect short end to the breather fitting on the driver valve cover.
8. Shorten the line on the T-fitting, that goes under intake, to make it match up closer to actual distance.
9. Install short piece of line on passenger side valve cover breather.
10. get a 90 degree elbow like what is on the driver side line.
11. Cut a 2.5 inch piece of line and install on open end of T fitting, rotate forward.
12. Cut piece of line that will reach to the catch can fitting.
13. Be cognasinant of the line, so that it wont get caught up in belt system.
14. Make sure you install the filter, and close the pet cock on the catch can.
15. Your done.
The system will longer be pressurized, it will use standard atmospheric pressure, to keep that nasty oil and condensation out of your intake.
Enjoy.
15. Your done.
Enjoy.
