hurst line lock question
JTS VENOM PERFORMANCE
Preferred Vendor
SRT10 heaven
got a question
most definitly most here that run a line lock is using a hurst.
and the best mounting is Justins Bracket by far:rock:
but I think the lines I had made up may need to be a tad different.
I had them made with straight ends, and after looking at Justins pics , it looks like one end may need to be a 90 degree bend?
I cant use my truck for testing on this, since everything on my fenderwheel is located differently from a factory truck
so if anyone has suggestions it would be appreciated, and maybe I can run back tommorrow and get a piece or two, then ship it to Eddie for test.
Thanks in advance:rock:
looks about right with a fles line that one from mc to solenoid about 5 insches would work instead of 7 like we talked about, i was thinking it went to the other fitting until i looked at kevan's pics again.
so mat not need 90 degree?
Both lines from the MC should be 90 deg.
Input to LL should be Straight.
Output from LL should be Straight.
Input to ABS controller should be Straight.
Call me if you need pics, Tony.
