Hurts the gray matter.
doesn't seem possible...there solution doesn't make sense either. They start w/ Up down up, but WE start with Down Up Down. And you cant solve it by going backwards because if you look at the 'solution', whats the last move they do??? They flip the middle cup over (BY ITSELF, not in a pair) like explained in the directions...so they broke there own rule.
As I said, I don't think its possible
-Red
That's the trick. They don't expect you to notice that the starting point is reversed form the demo. With the starting point of Down-Up-Down, the only possible solution is Up-Up-UP. With the starting point of Up-Down-Up, the only possible solution is Down-Down-Down. :joyman: :pcguru: :alberteinstein:
Cool. I solved it then.
Thats what I came up with:D
