I CHANGED CAIS'-SHOULD I RESET?
SANCHOBA
TEXAS A&M DAD
INGLESIDE,TX.
i installed a JMB CAI (replacing a K&N),should i reset the computer by removing the neg. cable for 15 /20 minutes? or is this necessary?
Not necessary IMO.
But it also would not hurt.
Disconnecting the negative terminal is like cold booting your desktop computer. After 30 or 40 miles of driving the monitors all reset and have the oem parameters set.
Looooooooooooooking gooooooooooooooooooood!
thanks, guys! looks like i'm back to working full-time again.....so back to modding! 4:56s' next!:rock:
ya but that catch can goes on the inside ,,,but i could see it working were you got it ,,that way you dont have to clean the box out when you drain it :p
lookin good man :rock::rock::rock::rock:
i ran an extension through the box & put Justin's valve on it. easier to drain & it drains on the ground
:rock::rock::rock:
:rock::rock::rock:
To the ground? You are creating a toxic waste dump...it may require a superfund clean-up site...say it isn't so!!!
its true its true.
all i have ever got out of mine is water
ZCx said:
its true its true.
:eek:And that water was getting recirculated back into your intake? When I took off my TB I was amazed on how much black oil was pooling inside the intake just behind the TB. It was simply disgusting.
wait till ya see your intake valves. :(:(
it surprised me when i had the intake off for the plug wires.
made sure the valves were closed, got off what i could, sucked out the small stuff.
as far as water recirculated, doubt much if any. most is from condensation from Justin's catch can bein away from the engine
