tarheelguy said:
hey guys, if anyone needs specs or possibly instructions on repair,removal, of pretty much anything. i can acess alldata. i dunno if anyone else here has acess too it. if not maybe make this a sticky and people can PM me and i will get back with you asap, i check the boards pretty much every weekday.
Rusty
Can you look up the wiring colors on the PCM Connector # 32 (this is for the install of the Split Second for the Paxton SC, I want verify the docs for the Paxton are the same for 2006 QC.
#32 Should be a black Connector:
Pin # 8 - Brown/Light Blue > Crank Position Sensor
Pin # 18 - Dark Blue Gray > Cam Position Sensor
Pin # 2 - Pink with Gray Stripe
Pin # 4 - Blue with Green Stripe.
Also does anyone know on the Pin #8 and 18, do I cut the wire and splice the Split second into the wire so its like this.
Pin # 8 > Brown/Light Blue > Gray/Black on Split Second
Brown/Light Blue from CPS > Gray Wire on Split Second
Pin # 18 > Dark Blue/Gray > Tan/Yellow on Split Second
Dark Blue/Gray from CMP > Tan Wire on Split Second
I am assuming that it goes inline.... but just making sure...
Scott.
