Bravo
To get the 4.88's to work, you use the Unitrax carrier which shifts the ring over to the small pinion (about 1/4 inch). 5.13's must use even smaller pinion as the ring on the 88's is tight in the housing.
To get the 4.88's to work, you must ever so slightly grind down one tooth at it's peak to allow the pin to go back in. This is what pete(maui)'s guy just did under the advice of unitrax, and what I'm doing too.
Unitrax claims that the slight removal is at the spot where there is virtually no load based on proper gear set-up and patterns. (were talking .010" bevel to allow for clearance).
Interested in those with 5.13's as to how the set-up went.
-J
-J
