mosrt10
What's the idle on a RC?
sorry i forgot to mention that i removed my IAC when i did this. my apologiesFSTJACK said:The butterfly angle/opening does not set the idle speed.
The idle speed is controled by the idle air bypass valve.
The angle/opening of the butterfly determins the TPS setting. This being the case the butterfly angle/opening needs to be set while reading TPS voltage through the PCM, via ALDL (assembly line diagnostic port)(plug under the dash).
