INFINITY WIRE COLOR CODE HELP!!!!!!
kickinassrt-10
Miami, Fl
Why do these damn dodge's have to be sooooooo complicated? I have the infinity sound system and need some help determining the wire colors to the radio! Any help would be good!
Can anyone help....see I have the POS infinity sound system that makes everything so complicated....i am no longer using the infinity subwoofer or the amp that powers the sub....so i bought a basic wire harness, connected all the wires and my kenwood unit turned on but no sound was coming from it...has anyone else not used the infinity sub and amp that powers the sub and get away with using the plain cheap wire harness????
did ya come off the "IN" of the factory amp or the "OUT" of the factory amp.
talkin the main amp in the dash
I used an a wire harness and I came right off the back of the radio input there is 2 plugs there (bigger one and a small one) The wire harness only used the wires from the bigger plug and none from the smaller plug...the radio turned on but no sound was coming out (im thinking the smaller plug is for the amps????)
If you don't want to buy the expensive harness module just bypass the amp. Yes it is complicated thats why the damn part is expensive LMAO:D
Can't really do much with the plug. Have to bypass the amp that is behind the passenger airbag (silver one) the sub amp (that you aint using) runs from there too!
thanks frank i knew you would have the answers......i got your pm also..the link didn't go through for the colors...i need the colors so i can run a lo/high pass filter to use the RCA outputs....i thought the sub amp was under my center console seat...i un-pluged it and my sub stopped working????? also bypassing seems a little too much...i'll just wait and spring for the correct harness....damn did they make anything easy on this truck....or cheap for that matter.....lol
Yeah unfortunately the wiring on our trucks are nutty. I am working on a Remote Start, Keyless, Alarm on Perk's Truck and we are having wiring issues as well. So many damn wires that do different things using resistances. Have to have the right modules to work the electronics correctly.
