interesting
stick
pensacola
A Lesson in Acceleration:
> First, some useful info:
> * One Top Fuel dragster 500 cubic inch Hemi engine makes
more horsepower
> than the first 4 rows at the Indy. 500.
> * Under full throttle, a Top Fuel dragster engine consumes 1=
gallons of
> nitromethane per second; a fully loaded 747 consumes jet fuel at
the same
> rate with 25% less energy being produced.
> * A stock Dodge 426 Hemi V8 engine cannot produce enough
power to drive the
> dragster's supercharger.
> * With 3000 CFM of air being rammed in by the supercharger on
overdrive, the
> fuel mixture is compressed into a near-solid form before ignition.
> Cylinders run on the verge of hydraulic lock at full throttle.
> * At the stoichiometric 1.7:1 air/fuel mixture for nitromethane the
flame
> front temperature measures 7050 degrees F.
> * Nitromethane burns yellow. The spectacular white flame seen
above the
> stacks at night is raw burning hydrogen, dissociated from
atmospheric water
> vapor by the searing exhaust gases.
> * Dual magnetos supply 44 amps to each spark plug. This is the
output of an
> arc welder in each cylinder.
> * Spark plug electrodes are totally consumed during a pass. After
1/2 way, the
> engine is dieseling from compression plus the glow of exhaust valves
> at 1400 degrees F. The engine can only be shut down by
cutting the
> fuel flow.
> * If spark momentarily fails early in the run, unburned nitro builds
up in> the affected cylinders and then explodes with sufficient force to
blow
> cylinder heads off the block in pieces or split the block in half.
> * In order to exceed 300 mph in 4.5 seconds dragsters must
accelerate at an
> average of over 4G's. In order to reach 200 mph well before half-
track, the
> launch acceleration approaches 8G's.
> * Dragsters reach over 300 miles per hour before you have
completed reading
> this sentence.
> * Top Fuel Engines turn approximately 540 revolutions from light
to light!
> * Including the burnout the engine must only survive 900
revolutions under
> load.
> * The red-line is actually quite high at 9500 rpm.
> * The Bottom Line; Assuming all the equipment is paid off, the
crew worked
> for free, and for once NOTHING BLOWS UP, each run costs an
estimated
> $1,000.00 per second. The current Top Fuel dragster elapsed
time record is
> 4.441 seconds for the quarter mile (10/05/03, Tony
Schumacher). The top
> speed record is 333.00 mph (533 km/h) as measured over the
last 66' of the
> run,
> (09/28/03 Doug Kalitta).
> Putting all of this into perspective:
> If you were riding the average $250,000 Honda MotoGP bike.
Over a mile up
> the road, a Top Fuel dragster is staged and ready to launch
down a quarter
> mile strip as you pass. You have the advantage of a flying start.
You run
> the RC211V hard up through the gears and blast across the
starting line and
8000 hp....... pure fukking sex if ya ask me LOL
Here's my buddy Terry Haddock's ride.
Yeah, sex with a T-Rex
This part is out of date. At least the 4.441 seconds is. Tony reset the record in the last race, in the last round to win the championship last year. I thought the speed record had been broken also, but I don't remember for sure.
last 66' of the
> run,
yes he had to set a new et and mph record AND win the final round.....which he did.
If I remember right, the MPH does not win you any points.:dontknow: :confused:
Is that right Jack?:confused: :dontknow:
Lemme look at my back issues of National Dragster, if memory serves me correctly that is what Tony nneded to do to knock Kallita out of the top spot.
I have that final race event on VHS also I can dig that out too.
This is from the NHRA Web Site.
I was pretty sure that MPH did not earn points, only the ET did.
NHRA POWERade CHAMPIONSHIP
Contestants in each of the Professional racing categories compete for the NHRA POWERade Championship title on the basis of total points won at NHRA national events.
NHRA NATIONAL EVENTS
Winner 100
Runner-up 80
Third-round loser 60
Second-round loser 40
First-round loser 20
Additional points are awarded at national events as follows:
10 points to all contestants - 1 qualifying run required.
20 points for establishing an official ET record.
Qualifying positions earn points as follows:
1st 8
2nd 7
3rd 6
4th 5
5th & 6th 4
7th & 8th 3
9th thru 12th 2
13th thru 16th 1
Yes you are correct, my mistake.
He went a 4.428 @ 327.98 mph with a .095RT....
