bigike
Here, this is what i was trying to explain to you, but the steriods had clogged your ears!
Heat spools a turbo....................
In short, gas temperature, pressure, and volume are all related. Compress a gas (reduce the volume) and pressure and temperature goes up. Let it expand, and temperature and pressure go down. Increase the temperature, and the pressure goes up (in an enclosed space) or the volume goes up (it expands). Finally, gases want to flow from a high pressure area to a low pressure area, and the greater the difference, the bigger the push. (Pop a baloon, little bang. Pop a welding O2 cylinder, big bang)
http://www.turboclub.com/turbotech/TurboFun1.htm
