Jerry Bell's Truck
dancragin
Hi everyone,
Its been a while since I have been on the site. I thought I would reach out to you folks and see if we can find a good home for Jerry's Truck. He passed away from cancer suddenly, just after he retired. I am just trying to help his widow find a good home for it at a very reasonable price.
The truck is turnkey with over 60k in upgrades. Too much to list, but here is some of it. It was his pride and joy daily driver, 35k miles
New Forged Engine (100 miles)
Our Custom Paxton Supercharger system
Heat exchanger and pump upgrade
Custom Air intake
Water Meth injection
11 psi pulley
Headers and Mids (catless)
Magnaflow Cat Back
Custom shifter
Light flywheel, Clutch and Viper Hydraulic Upgrade
Ford 9 inch rear end with 4.56 gears and Detroit Locker
Cal Trac's Traction bars
Wilwood Brakes and SS brake lines
QA1 suspension- Lowered
Line lock system
Front slotted rotors/ EBC's
Good tires and production wheels
Extra set of Bogart wheels, front and rear with drag slicks
Boost, RPM, AF, Data logging gauges.
Shift light
Double DIN custom stereo
Back up camera
Offered at a firm 30k- I will set you up with his widow.
Dan Cragin
310-597-6295
Nice to see u back. Can u give us a little info on the engine build. Specs, parts that were used. Cammed? Head work or stock heads? Billet mains? Stock damper or ATI?
Sent from my LG-H918 using Tapatalk
That's slick!!
Sent from my iPhone using Tapatalk
The engine makes an honest 700hp. I think it dyno tested around 650whp
back when we had it at DC.
It was a standard rebuild, just forged pistons and a good valve job. Stock cam. Anything over stock boost we suggest a piston change.
There is a lot of value in this truck. A super fast daily driver.
I met Jerry back in the day, very nice guy, and always kept his truck in great shape. R.I.P.
Thanks Dan. Any details on the rear end? Where did it come from?
Its a full DTS rear end with Cal Tracs, about a 4k upgrade. Truck is a 2004 with 39k miles. Engine is brand new. I spoke to his widow MJ and she will take 30k, no less to a good home. Here are some more pics.
