JMB Fascia Saver Prebuy
JMB Justin
Preferred Vendor
Hillsboro MO
Finally some pics, we have some work to do on getting the exact contour, but this material is awesome, black, very flexible, etc., will not shatter or crack. Bolts up in minutes, very easy install. You can see where we need to do some work still (it will be out the same amount the entire way around), but we are close, should be getting the final one cut early next week. Im going to have a prebuy on these for $60ea. and they will go up to at least $75 after this 2 week prebuy (ends 5/15). Shipping is probably going to be $30 because of the size (lower 48 states). If I am able to find a cheaper way to ship I will refund the difference. You can paypal to [email protected] or call me at 314-540-1541. These will not ship until the 3rd week in May.
Justin
I do not, it uses all the stock bolts along the edge of the fascia and only extends back approx 1" past them (towards the back of the truck). Very lightweight!
Justin
MUAHAHAHA... Good... Good.... Good.....
Just in time since I will be placing an order for mids soon.
the only question that i have...since mine is torn all to hell...
say you were coming out of a steep driveway, if you didn't have the saver, the fascia would more than likely "slide" and scrape the bottom of the fascia...which you can't see anyways, most of the time...but if the fascia saver was to "catch" on the asphalt or concrete somehow, would your protector have the possibility to tear off the bolts that actually hold the facia itself on...or would the saver "break away"...as the saver is obviously much cheaper to replace than the fascia itself?
what do you plan on doin 4 wheelin that thing or what? it will still slide across it!
im in on this bro. wil send you some money monday.:rock:
hey justin think you could do something like this with your current part? maybe CF :dontknow:
cuz that would really set the front bumper off :D
