If you have lowered your Ram SRT-10 you need these custom sway bar end links to bring your sway bar back to parallel with the ground. When you lowered your truck you have effectively lowered the efficiency at which your sway bars work. Front end links with polyurethane mount and end link bushings, normal price is $129.99 plus $150 core, through april 09 they are 99.99 plus $150 core. 06 guys get to take an additional $20 off because there are no aftermarket sway bar mounting bushings available (you will still get the poly end link bushings). Rear end links with polyurethane mount and end link bushings, normal price is $109.00, through april 09 they are $95. These only fit RC's. The fronts also fit your buddies Hemi 02-06 so tell them if they are lowered they need to get hooked up too!
Heres the link for the fronts:
http://jmbperformance.com/store/product_info.php?cPath=66_93&products_id=259
Heres the link for the rears:
http://jmbperformance.com/store/product_info.php?cPath=66_93&products_id=260
You can order online and I will adjust the price after you put your order in, or over the phone at 314-540-1541. If you have questions please email me at [email protected] or PM me.
Thanks,
Justin
Thanks,
Justin
