Getting some stuff ready for the new website and thought I would throw this out there:
JMB Performance and PBJ have collaborated to design and test many different profiles over the years to come up with a line of readily available custom camshafts. All JMB/PBJ camshafts are ground by Competition cams to our specifications (some with proprietary lobe designs) on induction hardened cores for exceptional durability and long life. These are tested and proven designs that will pick up everywhere in the usable power range in both horsepower and torque. They are ground for a very broad power band with a noticeable but not radical idle, and are easy to tune. Your build is unique and a one size fits all cam is never the best choice; so we offer custom camshafts in different levels for naturally aspirated, nitrous, blower, and turbo applications.
All cams are $675 Valvetrain packages and pushrods are listed below as well, with pricing.
Naturally Aspirated:
NA58X - 22X/23X duration @ .050 lift - .57X/.58X lift with 1.7 rocker 114 CL
This NA58X grind is specifically designed for Naturally Aspirated applications that are stock or bolt on's only in a viper car, 6 speed viper truck or automatic viper truck. Stock drivability, huge low/mid range torque, very easy on valvetrain, focuses on durability/longevity
Requires single spring valve train kit
NA62X - 22X/23X duration @ .050 lift - .62X/.62X lift with 1.7 rocker 113 CL
This NA62X grind is specifically designed for Naturally Aspirated applications that are stock or bolt on's only in a viper car, 6 speed viper truck or automatic viper truck that also has an aftermarket 2500+ RPM stall converter. Stock drivability, tons of midrange, great for mild viper build or the heavier truck build focused on torque.
NA63X - 23X/23X duration @ .050 lift - .62X/.63X lift with 1.7 rocker 113 CL
This NA63X grind is specifically designed for Naturally Aspirated applications that are full bolt on's with/without ported heads in a viper car, 6 speed viper truck or automatic viper truck that also has an aftermarket 2800+ RPM stall converter. Great drivability, peak power 6000+ RPM, torque gains everywhere above 2500rpm. 100+whp/wtq gain with typical bolt on's over stock.
Requires dual spring valve train kit
NA65X - 23X/24X duration @ .050 lift - .65X/.63X lift with 1.7 rocker 112 CL
This NA65X grind is specifically designed for Naturally Aspirated applications that are full bolt on's with ported heads and increased compression in a viper car or reduced weight viper truck. Minimum 6500 RPM redline. Will work in full weight viper truck but trades low end torque for high rpm power.
Nitrous:
N62X - 22X/23X duration @ .050 lift - .62X/.62X lift with 1.7 rocker 114 CL
This N62X grind is specifically designed for Nitrous applications that are stock or bolt on's only in a viper car, 6 speed viper truck or automatic viper truck that also has an aftermarket 2500+ RPM stall converter. Exhaust lobe designed specifically for valvetrain stability with nitrous use. Recommended for up to 200hp shot.
N63X - 23X/23X duration @ .050 lift - .63X/.62X lift with 1.7 rocker 114 CL
This N63X grind is specifically designed for Nitrous applications that are full bolt on's with/without ported heads in a viper car, 6 speed viper truck or automatic viper truck that also has an aftermarket 2800+ RPM stall converter. Exhaust lobe designed specifically for valvetrain stability with nitrous use. Recommended for 150hp+ shot.
Blower:
B62X - 22X/24X duration @ .050 lift - .62X/.62X lift with 1.7 rocker 114 CL
This B62X grind is specifically designed for Blower applications that are full bolt on's with stock/mild ported heads in a viper car, 6 speed viper truck or automatic viper truck that also has an aftermarket 2500+ RPM stall converter. Recommended for 6-12psi.
B63X - 23X/24X duration @ .050 lift - .62X/.63X lift with 1.7 rocker 114 CL
This B63X grind is specifically designed for Blower applications that are full bolt on's with stock/mild ported heads in a viper car, 6 speed viper truck or automatic viper truck that also has an aftermarket 2800+ RPM stall converter. Recommended for built engines running over 10 psi.
B64X - 23X/24X duration @ .050 lift - .64X/.63X lift with 1.7 rocker 114 CL
This B64X grind is specifically designed for Blower applications that are full bolt on's with ported or upgraded heads in a viper car, 6 speed viper truck or automatic viper truck that also has an aftermarket 3200+ RPM stall converter. Recommended for built engines running over 15 psi, minimum 6500 RPM redline.
Turbocharged:
T62X - 23X/23X duration @ .050 lift - .62X/.62X lift with 1.7 rocker 114 CL
This T62X grind is specifically designed for Turbo applications that are full bolt on's with stock/mild ported heads in a viper car, 6 speed viper truck or automatic viper truck that also has an aftermarket 2500+ RPM stall converter. Very versatile cam that can work in low or high boost applications and have excellent drivability.
T63X - 23X/23X duration @ .050 lift - .63X/.63X lift with 1.7 rocker 115 CL
This T63X grind is specifically designed for Turbo applications that are full bolt on's with ported or upgraded heads in a viper car, 6 speed viper truck or automatic viper truck that also has an aftermarket 2800+ RPM stall converter. Recommended for built engines running over 10 psi.
Custom:
We can custom grind any cam for any application. Call or email me with a detailed build list and we can build for your specific application.
Valvetrain Packages:
Single Spring Valvetrain Package
This single spring valvetrain package is designed specifically for our smaller and midsized custom camshafts. Can be used with any of our 62X and smaller series cams, however the Dual Spring Valvetrain Package is a nice low cost upgrade for the 62X series of camshafts. Includes single springs, locators, and valve seals.
Price $399
This dual spring valvetrain package is designed specifically for our larger custom camshafts. Can be used with any of our camshafts except the NA58X camshaft. Includes dual springs, titanium retainers, locators, and valve seals.
Price $425
Pushrods:
Available in 5/16 for 90% of camshafts we sell or 3/8 in. Diameter for severe duty. Made from 4130 Chromoly, 0.080 wall. Avaialbe in multiple lengths, each application must be checked for proper length. Set of 20
5/16" Chromoly
Price $169
3/8 Chromoly
Price $189
Pushrod Length Checker
Price $19
Nitrous:
Blower:
Turbocharged:
Custom:
Price $399
Price $425
Pushrods:
5/16" Chromoly
Price $169
3/8 Chromoly
Price $189
Price $19
