Misterhemi03
I was thinking if it was worth it to have just the rear cats cut off and weld straight pipe in. Is it worth it for power boost, or better sound? Thats with the stock front set of cats still in place.
Stinker said:Actually bro the upper cats or the ones closest to the manifolds are the most restrictive, tightly wound aluminum, very very restrictive, the lower ones arent that bad.
What he said.:rock:Silent D said:If yer gonna go....................why fk around...:dontknow: .............go all the way...:burnout: :rock:
SD
SD
Black1 said:Do the rear cats have O2 sensors, or just the front? .... can't remember...
Misterhemi03 said:I was thinking of a cheapo way to get some more power and better sound. I dont really want it too much louder than it is now. Already have magnaflow cat back.
Rice Eater said:if you are looking for a noticable SOTP power increase then you'll have to do cut out all the pipe between your manifolds and muffler and go straight. I am currently running mopar LT headers w/ catless mids and a magna flow muffler w/ turn down tips......but its loud! i don't think you'll notice as much just doing half of the pipe and not the other. just my opinion:dontknow:
Misterhemi03 said:I was thinking if it was worth it to have just the rear cats cut off and weld straight pipe in. Is it worth it for power boost, or better sound? Thats with the stock front set of cats still in place.
Stinker said:I guess they are different Patrick , both of my sets the aluminum was at the top , or foward:dontknow: but we know haw the factory can be
If ya want to get better performance and sound, then do this, either cut and remove and reweld as me and patrick both did, looks stock, sounds great, but most muffler shops want do this , so you would have to be able to do it yourself.
The second option is to go to the muffler shop and have them fab up some mid pipes and install some hi flow cats. easy and cheap.
If you do this have them make the cats to where you can remove them, and tell them its for when you go to the track.
You can get cheapo Cats also for about $50 from summit or Jegs, that are removable, and after you have them installed , takem home and knckem out
it is worth it, like Patrick said, with both removed, you should get about 25 hp and it will be at the Rear Wheels
Misterhemi03 said:I have the magnaflow cat back already and I think I am gonna take a crack at gutting the cats. Would I still need sims after the cats are empty?
RedSrt007 said:I agree...I used the plasma, cut open all 4 cats, gutted them, and rewelded them back. Looks completely stock, and dyno'd for a good 28hp
I have another stock set to put on when the time comes....
I went out and double checked, the rears are the stainless mesh, and are the restictive ones, not the fronts...
