Just got back from the track...1st cool night!
Rice Eater
Fort Lauderdale, FL
First pass was 12.9 on motor. Got the bottle heater working and put in the 150 jets and ran a 12.212 at 116.74 mph. I am conviced a bottle heater is the key!! That was only at 900 psi. My 60 was still only a 1.9 so still some work to do there!
Congrats!!! :D Nice runs....looks like if you can get that 60 down with the DR's might snap a 11.9 ;)
Blakewilder said:
Hey Riceman....how high will your kit go on HP?? 200 or 250????
Thanks for the props everyone....I was tickeled to death! I was also stoked to get in the 12's on motor. I was starting to think I'd need a flash to do so. Blake the Zex kit is only good to 200HP. I figured this was a good entry level kit for me to have fun with and eventually blow it up so I can do a monster build w/ forged internals and those wicked striker heads and a Direct Port System!
I was talkin to a few old guys that have been racing for ever and they were tellin me that we wouldnt see much difference between Direct Port and non until we got over 3-400 hp shots.....we would be FLYING with 400 shots....yyeeeaaahhh!!
;) The heat/bladder is the key. You can't go to far, but 1100/psi always worked for me.
And it works in reverse, when you fill the tank submerge it in a tank of water and ice, keep that tank cool when filling and you'll get more product in the tank! :dancing: at a lower pressure. :D
..... and nice run!
good luck,
Quick
..... and nice run!
good luck,
Quick
Aint that the truth!!! Right after they filled my bottle the pressure was only 600 lbs and w/ the 125 jets it only ran a 12.6. Finally she heated up to just under 1,000 and a huge SOTP difference. I hate this damn Zex Bottle Heater though.....it does not stay on.....it goes on and off on and off like a heating pad so you don't forget and leave it on and blow the thing. Downside is it takes sooo long to get warm! I might take it apart and try to remove that mechanism and just hard wire it.
Blake.....I can see that point....but is the Direct Port a lot safer? Maybe a Roe SC would be more fun anyways to have the power every time you start it up!
Fast400.....wish I could've seen yours before I bought! I think I'd loose my ass IF I could even sell mine....there are so many for sale! Kinda fun to do it on your own though....means more.....I think I'll buy a motorcycle for the down time but that is a wayyyyyys out....unless she blows soon!!!
Blake....hows your truck running? When you gettin her back? I can't wait to see your truck in Bradenton or before then! Who is tuning it? Do you know any local tuners that can dyno my truck and dial in the A/F for a 150 shot?
Roe will sell you a VEC. Dave at True Performance will install a Vec (they stock them)....You would benefit from the VEC cuz they can add and pull timing and adjust your af. The VEC will control your nitrous also if you want. I called Roe originally and they said that they were too busy and they sent me to True Performance.
Gotcha....I am familiar w/ the Vec.....damn those are spendy!!!!! I'll probably hold of on that for awhile....but that seems to be the best bet since you can have street tune and a Nos Tune.....and maybe a NOS tune w/ Race Gas!!!!??
thats the only way you will benefit from the race gas.....add more timing with the VEC. I like it because I can hook the laptop up while im running and make adjustments between runs.
