The proper way to decide the size of the pistons is to see how much material needs to be removed from the cylinders in order to clean up them up. Then order a piston that size, and have the bores machined and finally honed with a torque plate to achieve the proper piston to cylinder clearance for your application. So, in other words what sizes pistons I have or anyone else here has may not work for you.
