LATEST THINGS
Status
Not open for further replies.
LOL I know better.:D
you're probably correct........
Radiator and fan
our revised aluminum radiator , with larger thicker core, revised cooling, designed to work on autos and manual SRT10's
available only thru JTSVP , will work with oem or our aftermarket fan shrouds, designed to keep the large builds uhum, a ton cooler:D
Tony, How much for radiator and also fan setup?
the set up from CR is going to be $1695 for the radiator and about $695 on the shroud with complete fans and wiring from spal
bought together they will be a little cheaper, we are still working on specs and pricing
I do have a first proto radiator an shroud that I can let go cheaper
Is the 7th of Feb. good for you Tony. My daughter first birth day ln the date i told you. If I miss that the wife will kick me out. :)
You actually gonna drive your truck up there?
And yes, she will kick your butt if you miss the first birthday. :D
I will look and see, first thought , yes, but mind is a little elsewhere this week, trying to get caught up on alot, plus everyone of my distributors is still closed and its pissing me off:D
You supposed to be closed too :aetsch:
is 06venom's truck back to him...?
would like to see the finished product.
Status
