I have the Stinker (DTS) rear end with Wilwood rotors and calipers.
Both calipers have dripped a little brake fluid from the start. Now one of them is really leaking badly. I can't find the leak from any of the four bleed valves, so the only conclusion I can make is that the o-rings behind the pistons are the cause.
Anyone else had this issue? Any one have a solution?
I am going to pull one of the calipers and put on a spare...does anyone know the pads that should be used?
