Rice Eater
I replaced my NOS, Bottle Heater and Line Lock switches tonight to LED switches. I rewired all 3 accessories as well with all new connections. All of the accessories have their own ground coming off close to where they are mounted.....the switches I only have the power supply on one terminal and another wire going to the accessory which has its own ground. The switch has a thrid terminal for a ground which I did not wire......yet. I didn't think I needed it cause of the other grounds straight off the accesory. Well after testing.....I know now I need the ground off the switch to make it light up. Was getting too late to finish.
Here is my question though. The NOS box containing the selonoids has an idicator led. I flipped the switch which did not light up but the indicator on the box did. However.....the selonoids weren't firing. Its like it is not getting enough juice to click em open. Might adding a ground off the switch increase the juice through the circuit....or will adding the ground just make the light on the switch come on?
Damn that took a lot of words and its probably confusing but I can't sleep so what the hell:dontknow:
