Just in case you have to be a member to see the post, here is the data:
PRICE REDUCED AGAIN 20,000 OBO MAKE OFFER
PRICE REDUCED! AGAIN! 21,500 OBO
THIS IS MY PRIDE AND JOY.
located in houston texas.
I HAVE A TON OF PICS. EMAIL ME IF YOU WANT THEM
alexnollathotmaildotcom
832-797-9114
Im selling it, due to the fact that im moving on in my life, and need a more practical vehicle to drive. THIS IS A ULTRA CLEAN TRUCK! I have owned this truck from 10,000 miles. I am a BMW Master Technician, and a ASE Master Technician. This is my personal truck, that is driven on the weekends, and occasionally to work. I have kept absolutely rediculous care of this great truck. All records have been kept. Over 5500 dollars in receipts are available on request. All maintenance has been done by myself. This truck has had its oil changed every 5,000 miles with Mobil One full synthetic 0w-20 oil with a Mobil One oil filter. Magnets have been on the oil filter, to catch any metal debris. I add quart of Lucas synthetic oil treatment with every oil change. My Lightning is an incredibly fun truck to drive and hot-rod around. I have no objections to test drives or inspections before purchase.
THIS TRUCK HAS BEEN INSPECTED AT A DEALERSHIP AND IT IS AVAILABLE UPON REQUEST.
Here are a list of modifications and other items that i have done or installed.
BMW 330i Bi-xenon HID headlights that were grafted into the stock Lightning headlamps. These are fully functional and are the only headlights you will ever find like this. NO ONE HAS THESE HEADLAMPS, I GUARANTEE YOU. I have been offered 1500 dollars just for the headlights, due to how unique and expensive they were to modify. these headlamps LIGHT UP THE NIGHT!
Cross drilled and slotted rotors on the front and rear brakes, with zinc coating for corrosion
EBC ceramic brake pads on the front and rear
Limited slip modified, with friction modifier
Ford Racing brake fluid
Bassani Cat back exhaust with polished tips
97mm Air Mass Meter with cone filter
6 lb Lightning Force quick change pully. total boost is 15 1/2 psi
New Gatorback belts on the supercharger and on accessories fully ported and polished supercharger
new supercharger oil
ported and polished throttle, gasket matched to the upper intake manifold
ported and polished upper intake manifold, gasket matched to the supercharger inlet
Johnny Lightning Diablo Predator performance chip with custom burned files. THIS IS INCLUDED IN THE AUCTION
LOJACK IS INSTALLED ON THIS TRUCK. THIS CAN BE TRANSFERRED TO THE NEW OWNER.
custom foot rest for driver, made out of diamond plate aluminum
22x10 inch black rims with a polished lip
305-40-22 Pirelli Scorpion Asimmetrico tires with less than 2000 miles on them front and rear
Factory Tech Total Domination 2800 rpm Billet torque converter
Factory Tech valve body and shift kit
Factory Tech Ultra transmission cooler with braided steel lines
Moroso 4 quart extra fabricated aluminum transmission pan. The transmission holds 24 quarts of Mobil One full synthetic transmission fluid. This transmission is bullet proof!
NGK TR6 plugs to handle the extra boost
Optima Red top battery
shaved door handles
Autolöc 50 lb door solenoids for the shaved door handles
Autolöc 35lb aluminum door poppers
shaved radio antenna
custom ghost flames, they are blue irredesant pearl with red rogue pearl tips. These flames done by me and shot with help from a friend who is a professional painter. it layed smooth as glass!
the front bumper was modified to be closer to the body, to get rid of the gap
Lightning Force Ultra heat exchanger (for the intercooler)
Red Line Water Wetter added to the coolant and the supercharger radiator
Intercooler under the supercharger was cleaned
the rear end was lowered 3 inches with drop shackles
6 disc cd changer
custom tint on the windows
new updated cylinder heads (so the sparkplugs dont shoot out)
All manuals, suppliments and brochures are included, in brand new condition
This truck Dynoed 389 to the ground!!! BE CAREFUL when its cold...
BURN OUT KING CONLEY'S PERFORMANCE BURN OUT CONTEST 2006
I have a Carfax report, and it is available upon request.
IF YOU WANT ANY OTHER PICTURES, I HAVE MORE. IF YOU WANT ME TO TAKE A PICTURE OF SOMETHING SPECIFIC, EMAIL OR CALL ME, ILL SEND IT TO YOU.
Things that I know are wrong with it:
its impossible to believe or listen to a seller when they say "there is nothing wrong". im not going to say that. the items that are KNOWINGLY wrong with this truck are only cosmetic. i know of NO mechanical defects or problems with my Lightning.
there are normal rock chips and what not on the grill. the rest of the front truck was re-cleared when the flames were put on, so no other rock chips are on the front of the truck.
I do not have a bumper grill for it. Im undecided what grill I want for it, and I think it looks killer with the big 'ole heat exchanger in the middle of it.
There is a crack in the fiberglass on the right side bedside. it is almost impossible to see, but I want to be as truthful as possible with you.
I was unfortunatly unable to avoid a retread on the freeway, damaging the right side body moulding under the door. this is not real noticable, but it is damaged.
There is a small chip on the left side fiberglass under the stepside. I believe it was parking lot damage.
Anyone WHO IS SERIOUS about buying this truck can check it out and personally inspect it before purchase. I'll give you a ride in it and you can decide on that. its a FUN truck to cruise in. Its great to go to a car show and get compliments from others about its looks. street shows are a great time with this truck.
im going to eventually bring it to the track... i am anticipating a mid 12 second 1/4 mile. I can probobly hit a low 12 second quarter with slicks.
OWN THOSE MUSTANGS, MESS WITH CORVETTES AND KILL RICERS!
any questions, dont hesitate to call! 832-797-9114
thanks! Alex
I will help with pickup and delivery, but shipping is not my responsibility. If you want it shipped, you need to arrange the pickup and IT IS AT YOUR COST.
I will drive it to your location for 1.00 a mile, with my motorcycle in the bed starting from my location in houston to where ever you want. THIS WILL BE AN ADDITIONAL COST, AND IS NOT INCLUDED, BUT IS AVAILABLE IF NEEDED. If you choose to do this, i will expect it added to the total amount when it is paid in full.
A deposit of 1000 dollars will be asked for if it is purchased. this will go towards the total cost, but it is so i can pull the truck off the market.
THE FULL AMOUNT IS DUE WITHIN 7 business days.
The vehicle is located in Houston Texas.
