LOW PRESS POWER STEERING LINE
SR71
I purchased the P.S. line upgrade kit and the oil cooler line kit.
I replaced the oil cooler lines this weekend. I went to do the P.S. lines and noticed the line that was leaking was the regular line going to the pump not the high pressure line, That or the Pump itself is leaking. Any one else have this issue?
My PS line was leaking from the part that goes into the pump from the top. It was running down (very small but it was wet). At first I thought my pump took was about to take a dump since it was at the bottom of the pump. So I went ahead and replaced it and decided if it was still leaking at the bottom of the pump I'll do the pump as well. My pump has been dry at the bottom, so the lines can leak from the top of the bottom.
thanks for the info. where did you get the line from?
I got my lines from JTS. The line from the top of the steering pump (next to where you put fluid in) is the line that is leaking correct?
