Lower t-stat
bigike
Katy (BY GOD) TEXAS!
Advanced autoparts has a 160/170/180 and 190 degree t-stats. Which should i get. I understand that I won't get the full benifit until I get my flash but for the time being, i do alot of at speed runs and believe that It could help. I'm thinking 170, and I'll add a little water wetter. Gonna get those a/c temps down a little also.
thanks yall.
IKE
Advanced Auto Pars 170
thanks yall.
IKE
i dont think those are for the gen3 engine. we have the 170 stat, its 35 bucks
bigike said:
Boomer does yours come with instructions? and what would shipping be? 77449
i can walk you thru it over the phone, like 6 bucks for shipping.
I believe Boomer's is the only one in town! Unless, another aftermarket one has come into the ball game. Stick with the 172 T-stat. Anything less, you will probably throw a code. Everything else is in the PCM, hyd fan and outside temp.
:call::call::call::call::call::call::call::call:Remove 4 screws, take out stock t-state, install new T-stat, rock on.:rock:
Boomer, I still have a new exhaust I want you to look at under my truck! :girlshit:
RedSrt007 said:
step by step instructions in the DIY section...
And they were very accurate.
Best tip - let her cool all the way down before you try to get at that terrible bottom bolt.
Other than that bolt, it was a breeze.
Dont be surprised if it still runs the same temp after install.Alot guys still running 200ish with a 170 t-stat.!!!!!
Yeah it still runs 200 on hot day in traffic but out on the highway in 6th it cools to about 170 which it never did before
I kepted the 170 when I removed the stage 2 for the nitrous, truck runs just as hot as it did with the factory t-stat.
Same deal with the LX models..I have a 180 (stock is 203) in my SRT8...temps run 200-215 in traffic...185 on the HWY...B&G can flash the PCM to turn the fans on at a lower temp...I have a switch to manually turn the fan on...with the fan on my temps stay around 190 on a hot day in traffic..
Right, I understand that with no air flow there is no exchange of heat. but at speed this will help. And I will get the PCM in due course:)
Is this post writen ok. I mean I know its no battlefield earth or anything but, hell this is the INTER F'N NET! :)
