DRamSrt10
Texas Yellow Fever said:They're just stuck you have to stick a large screwdriver or something like that in there and pry them apart from the mounting perch on the axle tube.
Ok thanks!!
Ok alright, thanks. I got all 4 U bolts off but how can I get the leaf spring break apart from the ....something....a rod that hold the brake rotor? Do you know what I am talking? I mean...I can't install the blocks because the leaf spring are in the way.
07-20-2007 03:52 PM
TREKER said:Just got mine today!!!! Thanks SLH!!!! :rock:
Now I would like to get a little better understanding of what you guys are talking about. What is getting stuck?
ccfeyh said:Ok, when you loosen the u-bolts and jack up the rear end, it will not seperate from the springs, so take a large screw driver and pry the rear end from the springs, continue jacking until you can get the block in there. Then slowly lower the rear end, making sure the "pin" on the block lines up with the receiving hole in the rear end, it will not just slip in and you may have to pry a little to align them (side to side or front to back). Let the rear end sit on the pin, full weight. Then start tightening the new u-bolts and the "pin" will press into the housing on the rear end.
Now, drink a brew, then repeat everything on the other side. When you're finished, sit back and admire your new look.:rock:
Take your time, it will go together like butter, took me about an hour for the entire thing.
Fit95 said:ccfeyh
that is exactly what I tried - get it started and then tighten the ubolts to press them in - no go. I would keep that in mind for anyone who is trying that, if it doesn't just pop in - start reaming. My experience may be an isolated incinent. Mine were off, and needed grinding to fit. Looking at my truck today though, I can't believe how it changed the look of the truck. It looks so much better and not like a jacked up pickup truck.:rock: I love it even more now!
TREKER said:1. Does the spring come slapping down when it releases from the axle?
2. The pin you are talking about it the hole in the new block where it fits into?
3. After you start to lower it onto the blocks, you still have to pry it around until it seats?.
4. Is there a certain amount of torque you should go with on tightening them?
ccfeyh said:Here's pictures of mine installed http://www.vtcoa.com/forums/showpost.php?p=285252&postcount=139
Answers:
1. YES, be prepared and don't have something in the way. Just jack up the rear end about an inch or two, then use your screw driver to pry them apart.
2. The hole on the bottom of the block fits over the "bolt" that requires you to pry the spring loose. The pin on the top goes into the hole in the bottom of the rear end.
3. Just to get the pin aligned in the rear end, you'll feel it "drop" in and align. Now we're talking about moving the rearend not the block, when they come apart seems it doesn't want to just line back up. You could be lucky.
4. I don't remember what the tourque was, seem I remember reading somewhere that it's around 100 FTLBS, but I could be wrong.
Most important things is do one side at a time
TREKER said:1. So loosen the existing bolts on one side.
2. Take wheel off
3. Jack up the frame of the rear so the springs start to hang a bit. Then if they dont release after you jack it a bit, use the large screwdriver.
4. Take out existing spacers???
5. Install new blocks, align, lower, tighen each side evenly until it seats.
6. close it all up.
That about it?
ccfeyh said:You forgot the brew
TREKER said:Sorry...
:beer: :beer: :beer: :beer: :beer: :cheers: :cheers: :cheers: :cheers:uke:
uke:
uke:
uke:
Miss anything else?
