Lubeing the truck?
VIPR PWR
Well-Known Member
FL
Are there any grease fittings or what do you guys do to lube the truck?
That's a great question. I'm starting to hear lttle creeks and moans coming from the suspension when I take off in first gear...
No grease fittings from what i see....but when i do an oil change i squirt a bit of WD-40 on all the moving suspension parts...leaf spring eye bushings, control arm bushings etc...no funny noises!
Muffler bearings every 30K miles.
How do you grease the muffler bearing? Lube up the air filter for an overall treatment:D
And where are these located Bone:p :p ---I THINK MINE WERE REMOVED WHEN THE MUFFLERS WERE REPLACED:p :p . The tough ones I have to lube are the hub cap gaskets:D :D :p .....
Also it's difficult to get the rear shackles greased, damn angles of the zerks there( Stinker lowering Shackles that is!....I guess WD40 is the only option????
