Streetgang
Installed a new cover today
A couple of things that went with install.
1.Dropping the spare made it much eaisier
2.You might need a small chisel and a swinging press to remove the old cover.
3.After the fluid is drained...there is a small detent where the fluid will puddle in the bottom of the housing....I used my finger to swab it out...Quite abit collects there.
4.Cleaned housing with 800 grit paper and steel wool.Actually there was no gasket left....Maybe that is why there was only 1.5 Quarts of fluid in there...It must have weeped since the factory.I bought the truck with 14.500 miles...I am changing it at 17.500 miles
5.There is a previous post that says the Q-cab with this cover takes 4.5 quarts...Mine took 6....I used Royal Purple ....It had Friction modifier in it already.
6.Bought from www.extremediesel.com .....$228.00 and free shipping...Bought the trans-pan as well.
7.The correct cover is for a DANA 70...Thanks to all whom gave me the clarification on the Q-cab rear end.
8.You will feel the difference right away...The fit and finish is outstanding.(Same for Trans Pan)Maybe I am trying to feel good about the buy !!!!!
Thanks Bill :star:
Thanks Bill :star:
