Master/Slave Cylinder Install
jimmyg79
Michigan
Ok, so I'm going to finaly get the master and slave cylinder. Have any of you installed this yourself, and if so inlighten me on how to do it.
Mr. Jimmy I can give you a few details , but went to bed at 4.30am an jsut popped up, I shall think about it and write it up fo ya in a little .
you going with the viper stuff or the stock stuff?
its pretty basic bro, the master cylinder you unbolt from the inside of the truck, and also unclip it from the brake pedal.
down onthe tranny the line will run into the side of the tranny, push inthe line, and the small clip surrounding the line, and then pull the line out.
Naturally onthe slave, you have to pull the tranny to replace.
after getting everything installed, bleed the system, with a bleeder or you can open the system at the slave and let it force bleed to get to somewhere to have it bled.
Is there a shim that goes with the slave also? I am getting ready to upgrade my clutch system. I hope somebody makes a "Do it yourself" thread on installing a Centerforce- Viper master-slave upgrade soon!
