got a mds window rpm nitrous controller ,,,problem is i cant find out were i need to tap in to on the ecm plug to get proper rpm signal ,,anyone ever do this ,,need wire color and plug and pin number:dontknow: :dontknow: :dontknow:
Good question.bigike said:what pills are you going to use?
Sounds like fun,hope you dont go boom.Ironhead said:if jack can run a 250 so can i :rock:
bigike said:On my truck the tach signal is blu/yel on the bottom plug.
250, what rpm on/off?
Thats what mine is set at.:rock:Ironhead said:on at 3200 off at 5600 :burnout: :burnout: :burnout:
FATJACK said:Will have an answer for you in the morning. I don't think it connects to an ECM wire. BTW what happened to the directions I sent????
