savageR said:
I have a 77 chevy blazer 4x4 that I am fixing up for my son to drive when he turns 16. Is still a couple years out till he will be old enough. I have already got all the body work done, and a new paint job. I am now working on the interior and drivetrain. I want the truck to be reliable/bulletproof for him. It doesn't have to make a ton of power but just be sufficient for what it is. It currently has the original 400(6.6L)/350 auto combo, with the np203 transfer case. Is the stock set up worth putting money into? Or should I swap it out for something else? I don't see alot of aftermarket stuff for the 400.
Thanks
The 400 is a good engine ( basically a bored and stroked 350) the heads are the same except for some small steam pocket holes in the heads( other heads can be drilled using the head gaskets for templates ( if you need to)
The damper and flex plate has a counter weight (unique to to the 400)
I assume you are in a smog area so changing the engine may require the smog system from another engine would have to be used.
After market parts (headers , manifolds and accessories are the same as the 350). just check with the supplier. If you rebuild the engine, I would suggest
a lower compression piston set so you can run regular gas all the time and new seats and valves for the new fuel formulas.
Gas mileage can be helped by installing Warn lock out hubs on the front axel
The tranny is good, but, a turbo 400 is much better, but the turbo 350 can be rebuilt to hold up just fine.
There are bearing kits to put a 350 crankshaft in that block (makes a 366cu in) many like this set up as it eliminates the need for the 400 damper and flex plate.
Remember the first vehicle usually gets trashed so I wouldn't get to carried away. Just my .02 cents
Oh, try Peterson Publications for the Chevy parts and building book they sell as it has every combination of parts that can be used in the Chevy engines along with many pr oven mods.
